RR question
Old May 3, 2013 | 10:48 AM
Zfbod94's Avatar
RR question
http://www.summitracing.com/parts/CRN-10758-16/
I was wondering if anyone has used these. If so, what kind of review would you give them. Are they comparable to the Ultra Pro Mags?
I have a chance to get a complete set for $200 with very low miles on them. Would it be worth it or should I save for something better. I take the car to the track maybe 3 times a yr, other than that just a lot of spirited DD driving.
Old May 3, 2013 | 02:47 PM
Re: RR question
There are people using the Crane Golds. Nothing wrong with them.
Old May 3, 2013 | 03:06 PM
Re: RR question
GM used "modified" Crane Golds in the LT4 engines.
ROLLER ROCKER ARMS
The LT1's stamped steel rocker arms exhibited ball galling at 6400 rpm, so modified Crane roller rockers were substituted in the LT4 with lock nut and set screws to replace the conventional ball and friction nuts. Shims were added to maintain the valve stem accurately and the stud slot widened. The roller axle reduces friction measurably, the 2 lbs-ft reduction increasing economy and responsiveness. The rocker arms also have a roller tip. The LT4 has 1.6:1 and LT1 has 1.5:1 Rocker Ratio.
http://www.grandsportregistry.com/lt1vslt4.htm
Old May 3, 2013 | 04:02 PM
Zfbod94's Avatar
Re: RR question
Thanks guys. I think Im gonna spring for them. I have comp roller tips now, just looking to step up to the next level.
Old May 4, 2013 | 10:27 AM
KW Baraka's Avatar
Re: RR question
I was wondering if anyone has used these. If so, what kind of review would you give them. Are they comparable to the Ultra Pro Mags.......
They are a good aluminum rocker. But after having used them for about three years, I made the decision to never use aluminum rockers again.
Are they comparable to Ultra Pro-magnums? Hell.....I'd doubt they are comparable to the old Pro-mags.
Just my opinion.......
KW
Old May 4, 2013 | 10:58 AM
Zfbod94's Avatar
Re: RR question
^ Thats what I was thinking. I was just trying to use them as a reference point. Thanks for the advise :-)
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
