replacing a 95 motor with a 97?
Re: replacing a 95 motor with a 97?
You would just have to swap the 95 knock sensor into the 97 engine. You will end up with some unconnected items, like the crank position sensor.
You mean replace the timing cover so you can add the crank sensor/reluctor? You would also have to check the hub for the harmonic damper, since I think the later engines used a shorter hub to make a space for the CKP reluctor gear. And you would hve to use a 96/97 knock sensor. You'll also be missing a lot of hardware for the AIR system and the EVAP system. All of that could be swapped from one engine to the other.
