Replace struts?
Old Oct 30, 2003 | 01:47 PM
  #16
Visual aid for those requiring it.... .
MacPherson strut suspension
In the "strut" type suspension, the structure of the front suspension is a "3-link" mechanism. Since the elements of a triangle can not move, the "shock" becomes a "strut", serving as a sliding link, allowing the structure to move. This is a very "cheap" suspension to build, and is susceptible to severe, undesired changes in camber.
Unequal A-arm suspension
In an A-arm type suspension, the structure is a "4-link" mechanism. This has the ability to "move" without any sliding link. The spring and shock are just sort of "tacked on", as independant components, or in a "coil-over" form. More expensive to build, and provides superior camber control.
Old Oct 30, 2003 | 01:53 PM
  #17
fdxpilot's Avatar
Originally posted by Red96Lt1
Is there more than one type of Bilstein for a camaro?
Stock from bilstein, I think they have HD and Sport, Sport being the firmest. You can also get specially valved Bilsteins. I got a set from TByrne that was valved by SLP, the same as the optional SS suspension. I think they were $349 for the set.
BTW, the front coilovers are a b@#%h to change, as the springs are under a lot of tension. I went to autozone to get a spring compressor, and my shop no longer lends them out, after an employee used one wrong, and sent a spring through the side wall of the shop. I ended up paying a shop $100 to do it on their monster HD spring compressor.
Old Oct 30, 2003 | 02:04 PM
  #18
Red96Lt1's Avatar
Originally posted by stereomandan
The torx bit was a few dollars.
Dan
Do you remember what size torx?
Old Oct 30, 2003 | 02:07 PM
  #19
stereomandan's Avatar
I seem to remember size 50, but I'm not positive.
Dan
Old Oct 30, 2003 | 02:23 PM
  #20
Red96Lt1's Avatar
Thanks everyone for your help, and thanks injuneer for the visual aides
Old Oct 30, 2003 | 06:17 PM
  #21
SlowAssTA's Avatar
so i was right it is a strut....... cause it dont look like the unequal A-Arm suspension
Old Oct 30, 2003 | 06:40 PM
  #22
Try using your good eye.
Old Oct 30, 2003 | 06:56 PM
  #23
SlowAssTA's Avatar
sorry... i was wrong...
KYWes
Apr 3, 2015 07:59 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Magenta_Hearts
Mar 22, 2015 02:44 PM
dale3in98
Feb 14, 2015 12:18 PM
1996LT1Z28
Jan 14, 2015 08:09 AM
