Removing A.I.R. pump system....
Old Mar 22, 2004 | 06:47 PM
Black94mula's Avatar
I'm in the process of installing my LTs and wanna remove the entire a.i.r. system. Will there be anything I'll need to plug up or just remove all the components? Thanks guys..
Old Mar 22, 2004 | 07:40 PM
gb95zconv's Avatar
Obviously , youll have to plug the hole in the intake track......thats it .
Old Mar 22, 2004 | 07:44 PM
grossesexy's Avatar
thats all? i thought that there were several locations that needed to be plugged, or have small circular objects attached somehow to plug the system up. i checked shoebox's page for information on this but i didnt see anything about it.
Old Mar 23, 2004 | 01:10 PM
gb95zconv's Avatar
Oh yeah.....youll have to plug the hole in each of the exhaust manifolds when you remove the AIR valves. Youll need 2 22mm oil drain plugs for that. Nothing else needs plugging. Sorry I left that out the first time.
Old Mar 23, 2004 | 01:19 PM
He's putting in long tubes.... but he didn't mention whether they have the AIR connections or not.
When you remove the AIR pump, make sure there is a good fuse in the circuit. That eliminates the code/SES light.
Old Mar 23, 2004 | 02:42 PM
Yea no a.i.r. fittings on the headers. Wheres the intake port i'll have to plug?
Old Mar 23, 2004 | 03:18 PM
aintno6's Avatar
the one that connects to your CAI.
Old Mar 23, 2004 | 03:23 PM
TraceZ's Avatar
I thought that only worked for OBD1? Am I wrong? Wasn't 95 OBD2?
Old Mar 23, 2004 | 03:27 PM
Schearer225's Avatar
95 is OBD1, with a OBD2 port
Old Mar 23, 2004 | 03:32 PM
TraceZ's Avatar
Thanks. That makes perfect sense.
Now that you say that, I do recall hearing that before too. Leave it to GM to make everything logical.
Old Mar 23, 2004 | 07:50 PM
Cool, thanks guys..
REDNECKISBOSS
Mar 22, 2015 08:31 AM
rick350
Mar 14, 2015 10:46 PM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
Jul 4, 2005 05:00 PM
