Removing A.I.R. pump system....
I'm in the process of installing my LTs and wanna remove the entire a.i.r. system. Will there be anything I'll need to plug up or just remove all the components? Thanks guys..
thats all? i thought that there were several locations that needed to be plugged, or have small circular objects attached somehow to plug the system up. i checked shoebox's page for information on this but i didnt see anything about it.
Oh yeah.....youll have to plug the hole in each of the exhaust manifolds when you remove the AIR valves. Youll need 2 22mm oil drain plugs for that. Nothing else needs plugging. Sorry I left that out the first time.
When you remove the AIR pump, make sure there is a good fuse in the circuit. That eliminates the code/SES light.
Originally posted by Injuneer
He's putting in long tubes.... but he didn't mention whether they have the AIR connections or not.
Originally posted by Schearer225
95 is OBD1, with a OBD2 port
Now that you say that, I do recall hearing that before too. Leave it to GM to make everything logical.
rick350
Mar 14, 2015 10:46 PM
Jul 4, 2005 05:00 PM
