Recommendations on a head gasket.
Old Apr 14, 2006 | 01:02 PM
  #16
97 6SPEED Z's Avatar
Thumbs up Re: Recommendations on a head gasket.
For the stock LT1 piston, (with the four(4) valve reliefs cut into it), a good number to use for piston head volume on these calculators is 7.0 cubic centimeters.
Old Apr 14, 2006 | 01:06 PM
  #17
Oh yeah, and before I forget, I've been running the Mr. Gasket 5716 head gaskets on my set up, (see signiture), for about two(2) years now with NO problems whatsoever.
Old Jun 9, 2006 | 11:34 AM
  #18
user 647483's Avatar
Originally Posted by MeanGreen97Z
What CC did your LE heads end up?
I was told that the LE2s I got are 58cc
Old Jun 9, 2006 | 12:18 PM
  #19
93redBirdMan's Avatar
quick question. When I get my heads soon (used) should I get them shaved down a bit with a thinner gasket for added compression? How much hp would that really make? Would the added compression need to be mentioned when I get my new tune?
Old Jun 9, 2006 | 12:36 PM
  #20
You're not talking about a massive increase in compression.
But it's good for 5hp or so across the board
There's a calculator and some formulas floating around here somewhere.
I think we calculated mine to be 11.1:1 or so running LE2s with .026 gaskets.
Yours may be different depending on how they were ported.
I would probably mention the higher compression ratio (or at least the thinner
gaskets porting and milling) to the person doing your tune. Having accurate flowbench
numbers may help as well. (I'm sure someone else here who knows more about tuning can help you out)
Old Jun 9, 2006 | 02:45 PM
  #21
Kevin Blown 95 TA's Avatar
Cylinder head Volume (CC) = 54.00
Piston Top Volume (CC) = 0.00
Cylinder Bore (Inches) = 4.0
Cylinder Stroke (Inches) = 3.75
Deck Height (Inches) = 0.030
Head Gasket Thickness (Inches) = 0.039
Computed Compression Ratio is 12.3 to 1
Dude, you sure about that stroke? That could be messin ya up real bad if you got a stock engine with a 3.5 stroke in there.
Old Jun 9, 2006 | 04:45 PM
  #22
engineermike's Avatar
Fel-Pro 1074's. Good up to 21 psi boost and 143 mph in the quarter. . . so far.
Old Jun 9, 2006 | 04:57 PM
  #23
T/A KID's Avatar
engineermike has had good experience with the Fel Pro 1074's and thats what I plan to run on my D1SC 383. Can't go wrong with those from what I have seen.
Victor Lamb
Aug 26, 2017 02:52 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Queens94z28
Nov 20, 2014 06:03 PM
