Recommendations on a head gasket.
Old Apr 14, 2006 | 11:51 AM
MeanGreen97Z's Avatar
I've researched and i'm thinking of either the Impala .029" or the MrGasket 5716 .026". The car has no deck work to the block and the heads were only milled enough to get them nice and flat. I'd say no more than .010". Which would you run? I'm leaning toward the MrGasket 5716 to get a little more compression and get some more quench out of it. What do you think? I'm running ported heads with 1.7 ratio roller rockers on the stock cam.
Old Apr 14, 2006 | 11:56 AM
Javier97Z28's Avatar
Moderator
Re: Recommendations on a head gasket.
If you get the Mr. Gaskets make sure to buy two sets. Both sets I bought the top gasket was ruined by the packaging. Some run them as is, some don't.. I chose not to.
Old Apr 14, 2006 | 11:59 AM
I hear some people are having no problem with them..... it's hit and miss as far as I can tell.
hotrod18_69's Avatar
Fel-pro 1074 .039"
Old Apr 14, 2006 | 12:04 PM
Moderator
I have had 3 sets in a row, two were bad, one not opened. On the non opened one you can already see the gasket material coming up.
The third set was straight from Mr. Gasket, so it wasn't old store stock. If you're not in a hurry just get one set and order another set if u need to later.
Old Apr 14, 2006 | 12:05 PM
Originally Posted by hotrod18_69
Fel-pro 1074 .039"
Any particular reason?
Moderator
go with whatever gives you better quench, just advising on the situation
Old Apr 14, 2006 | 12:07 PM
No hurry at all. Stock deck height is around .020" while stock gaskets at .051" correct? I'm trying to figure out what my new compression ratio would be if I went this way. .020" deck height, .026" gasket, .010" milled on 54.5cc heads.
Old Apr 14, 2006 | 12:09 PM
Just like Javier97Z28 said... "go with whatever gives you better quench, just advising on the situation"
But i have never been a fan of Mr Grasket.. just because of the reasons listed.. I have never had any issuse with Fel-pros.. but thats just me..
Old Apr 14, 2006 | 12:11 PM
Now onto the quench.... i'm not sure exactly how to find which will give me the best. Is there an easy way to figure it?
Old Apr 14, 2006 | 12:26 PM
I'm getting a 12.4:1 compression ratio with the Mr Gasket 5716s.... I think that may be a little high for pump gas. Should I am for 12:1 or a little less?
Old Apr 14, 2006 | 12:28 PM
Moderator
eeeh, how are ya getting that figure...
stock deck height w/ the mr. gasket and a minimally shaved head gets you about 11:1
Cylinder head Volume (CC) = 54.00
Piston Top Volume (CC) = 0.00
Cylinder Bore (Inches) = 4.0
Cylinder Stroke (Inches) = 3.75
Deck Height (Inches) = 0.030
Head Gasket Thickness (Inches) = 0.039
Computed Compression Ratio is 12.3 to 1
Old Apr 14, 2006 | 12:29 PM
What CC did your LE heads end up?
Old Apr 14, 2006 | 12:36 PM
I'm sure the stock piston has some volume to it.... anyone know it... thats probably why im getting bad numbers.
