really crazy TPS/TPP problem
Old Feb 7, 2008 | 05:03 PM
thebufenator's Avatar
Alright, the other thread was becoming a mess and had information scattered all around, and the original issue is fixed, so I am creating a new thread to help make things clear....
Basically no matter what my TPS voltage is, my TPP is greater then 0%
TPS specs state anywhere between .2v and .9v is good and the ECM will baseline that as zero percent throttle.
Mine is not doing that. Anything greater then a TPS of .03v and it gives me a TPP of 1% or greater. Yes, with the TPS voltage that low it sets DTC 22 for being too low. Right now I have it set to .43v and the TPP is 7or 8 percent.
here are a few scans from yesterday:
http://i2.photobucket.com/albums/y2/...tuff/first.jpg
http://i2.photobucket.com/albums/y2/...0stuff/sec.jpg
here is my latest scan, you can see at the beginning where my rpm is 25 that I haven't started the car. TPS stays constant accross the scan, as does TPP. TPP shows 8% Notice the RPM and IAC.....the car is not trying to idle at all.
http://i2.photobucket.com/albums/y2/...0stuff/gah.jpg
Things I have done to try and fix it:
Tried a new TPS -> no change
Checked all the wires to the TPS, black is a good ground, gray has a good 5v, blue is the sense and corresponds to what the TPS shows on the scans.....
the TPS is slotted, and I can move it all around.....as I have said, the only way to get a 0% TPP is to move the TPS all the way to almost zero, .03 volts, which sets a DTC 22
I pulled the cables off the battery and pulled the ECM BATT fuse to wipe the ecm, no change.
Pulled the PCMForless tuned chip out of the ecm, no change
moved the wires around on the TPS, only fubard it worse, read a constant 5v....
running out of ideas here........
Old Feb 8, 2008 | 11:32 AM
any idea's anyone?
I am gonna try and find a different 5v source and see if maybe it is slow to build voltage there.......
Old Feb 9, 2008 | 01:08 PM
it would be really cool if someone had an idea.....
Kinda at my wits end
Old Feb 9, 2008 | 03:18 PM
96flame's Avatar
Couple things I noticed in your scans are the MAP and BARO are they listed in volts? If they are then you've got a problem there. The other thing being the IAC counts are maxed out and even when the counts go down the rpm stays the same so is the IAC motor even working? What are you using to get these scans?
Old Feb 9, 2008 | 04:28 PM
no thats not volts....
yeah the engine has a lumpy cam, the idle jumps around, so the IAC needs to move alot to get a different reading on the scan.
I am using freescan
Old Feb 9, 2008 | 04:36 PM
itzkwik's Avatar
If you moved your wires around and it made it worse,it sounds like you might have some bad wiring in some way or another ,bad connections,bad wire insulation somewhere? It's an idea.
Old Feb 9, 2008 | 09:11 PM
I meant I had physically swapped the wires on the plug.
Old Feb 9, 2008 | 09:31 PM
EXACTLY how are you doing the install of the TPS? Are you sure you are acurately indexing the hole in the sensor rotating element to the flats on the throttle shaft?
Have you tried adjusting the closed throttle voltage to 0.67V with the key on (making sure the blades are tight against the stop), turning the key off, and then clearing the PCM using the PCM BAT fuse? Start the engine, using Shoebox's procedure for "setting" the IAC.
http://shbox.com/1/4th_gen_tech2.html#iac_reset
That should get everything in synch. Then start the engine and read the PCM for TPS and TPP. Do not fiddle with the TPS to do any more adjustment, and do not try and set it to 0.03V to get 0% TPP. Leave it alone and see what happens.
As I recall, you have posted screen shots from Freescan. Have you ever done a full data log? Maybe you did, and maybe you even sent me one, but I don't remember it if you did.
Old Feb 10, 2008 | 10:59 AM
I give that procedure a go, but I am not sure it will change anything....
I did the same thing with .50v, still didn't baseline anything.
Are there specific PCM grounds that could be causing this? I have checked a few, so far they are all good, are there any really really important ones that I should check?
The scans above are full datalogs from freescan. The next time I go to the car I will record a longer length
warmeck
May 1, 2015 11:30 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
grabbem88
Mar 18, 2015 01:25 PM
PurpleHaze95
Aug 8, 2002 11:58 PM
