Quick question! 1st oil change (oil filter)
Old Dec 27, 2003 | 10:29 PM
  #16
JoeliusZ28's Avatar
Originally posted by S.J.S.
You can use any of them. I use Fram. As long as you change oil every 3k I dont think its worth it spending 8 to 10 on a filter.
Old Dec 28, 2003 | 02:40 AM
  #17
Unique07's Avatar
Fram..?
You hold him, I'll hit him...
Old Dec 28, 2003 | 10:55 AM
  #18
97BBlackZ's Avatar
1 more question.
When draining it do i have to let it ALL drip out or is it ok the just put the plug in and put oil in.
Right now its just dripping in drops.
and whats the best thing to do to clean up oil spills?
Old Dec 28, 2003 | 11:13 AM
  #19
ibanez6rg's Avatar
Sawdust or kitty litter.
Old Dec 28, 2003 | 11:28 AM
  #20
anaik's Avatar
If you didn't come across this in your search, here's a study someone did on oil filters.
http://www.scuderiaciriani.com/rx7/oil_filter_study/
Old Dec 28, 2003 | 12:17 PM
  #21
95BlackTA's Avatar
1 more question.
plug it up once its just dripping slowly. Theres gonna be some oil left over ofcourse, its all in the engine. Not exact science
OH and next time, put down a bunch of newspapers to catch all the oil so it doesnt get on the ground.
Old Dec 28, 2003 | 02:32 PM
  #22
MarkyMark's Avatar
Go
next time you might wanna warm up the car a little first so the oil is a little thinner and slightly warm........it will drain faster and easier this way.
________
Buy Bubblers
Old Dec 28, 2003 | 02:46 PM
  #23
97BBlackZ's Avatar
The ran was at running temps. when i did it, lil above 160.
Old Dec 28, 2003 | 03:05 PM
  #24
96 WS6's Avatar
When I drain my oil I always leave the pan under and the drain plug off. When it starts dripping slowly, I take the jackstand out and lower the car slowly until the exhaust is just about to hit the drain pan. Because of the angle more oil will drain out. I don't think it's completely necessary but I always do it anyway.
Also, you always want to dab a little oil on your finger and run it over the rubber sealing washer on top of the oil filter. It helps the gasket seat properly so it will seal and stay sealed.
The delco filter I use it a PF-1218. The PR-25 was the original one, and the PF-454 replaced it. You can also use the PF-35, but the 1218 is a big filter, I always say the more oil in the system the better.
Old Dec 30, 2003 | 02:44 PM
  #25
fredmr39's Avatar
Clean spills with spills - kitty litter, sawdust, xsorb powders, or, just dump some gasoline and rub like ur waxing ur floor (prevent stains). Also, if your concerned about every drop, assuming the front of ur car is on jack stands, kinda go w/ what 96 WS6 said -- better yet tho, if you want to completely level the car off, roll the front wheels up on ramps and jack up the back -- thats what i always do - safer also, i feel....
Old Dec 30, 2003 | 05:04 PM
  #26
BUBBA's Avatar
I go to Jiffy Lube, have a cup of coffee, use the head, pay the bill and go.
PCLZ28
Dec 24, 2015 05:19 PM
Sandersen511
Jan 13, 2015 03:49 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jul 4, 2005 05:00 PM
