Car wont start
Old Dec 30, 2003 | 03:45 PM
97TransAmG2's Avatar
Car wont start
I changed my plugs last night...afterwards i started it up to m,ake sure everything was ok...it all ran fine. I get up this morning and i put the key in...this time..nothing comes on...no dome lights...my headlights wont come on, the fuel pump doesnt pressure up, the starter didn't click...it appears as though NOTHING is getting power...I tried jumping it and nothing happened..any help would be appreciated
Old Dec 30, 2003 | 04:15 PM
BUBBA's Avatar
If you don't have dome lights, your battery connections are probably loose. That is if your battery is any good at all.
Perhaps someone else knows of a major fuse or security problem that might be the cause.
I've trid jumping a fried battery before and it wouldn't work. Don't exactly know why you can't just jump the cable alone, but it just seems like when it goes through a bad battery or one with loose connections or terminals, that it won't work.
First I'd check the connections to make sure they are tight (but make sure they are not corroded, since tightening them won't do any good if there is no contact between the cables and the terminals.
And...if you battery is past its prime, be sure to get a new one. JMHO
Old Dec 30, 2003 | 04:39 PM
BUBBA's Avatar
When jumping the battery the negative connection to the dead battery should go somewhere besides the terminal. Frame, engine, etc. You probably know this, but it also will tell you if your battery ground cable is loose underneath, if the car starts when you use proper jumping technique.
Old Dec 30, 2003 | 05:11 PM
good call guys. I took a look at it and battery was trash. I didnt think it would go bad overnight like that (nothing was left on in the car last night, It was the first thing I checked)..thanx a lot
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
