Quick Fuel Pump Question
Old Aug 30, 2005 | 11:05 PM
sick-1's Avatar
ok i installed a walbro 255l in my car today, hooked it up with everything still outside of the tank and when i hit the key.... nothing. Ok and so i havent hooked up the old pump which still worked to see if this is what the problem is but i wanted to know that since my pcm is not in the car (fixing to ship it away to get reprogrammed ) will that prevent the fuel pump from coming on? any help is appreciated.
Old Aug 30, 2005 | 11:09 PM
Re: Quick Fuel Pump Question
The PCM (pin A7) provides the fuel pump signal. With no PCM, you would have to go through the fuel pump prime connector to power up the pump.
Old Aug 30, 2005 | 11:20 PM
sick-1's Avatar
hey now thats what i wanted to hear, good that means that the pump probally is good then. thanks man.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
