Questions about putting heads back on
Old Feb 25, 2009 | 10:13 PM
dubbsix's Avatar
This might be dumb, but are the heads on the lt1 unisex? (is that the correct term lol). I made sure te steam hole plug were both facing backwards, but didnt see anything in the manual about which head goes to which side.
Also,
I got the fel pro bolt kit and there are two bolts that are longer than the shortest bolts, but shorter than the longest bolts.. do they go on the first and last bolt holes in the head?
As always,
Thanks in advance!
Old Feb 25, 2009 | 10:18 PM
Stl94LT1's Avatar
Yes, the heads can be installed on either side. But, if your steam holes are at the rear. You're good to go.
Old Feb 25, 2009 | 10:19 PM
dubbsix's Avatar
Thanks. Any idea about those bolts?
Old Feb 25, 2009 | 10:32 PM
Stl94LT1's Avatar
Yes
Old Feb 25, 2009 | 10:45 PM
dubbsix's Avatar
Yes
Alright! Thanks.
Old Feb 26, 2009 | 09:16 PM
BLKOUTZ28's Avatar
Are you running the cooling crossover. If so i'm pretty sure those holes need to be in the back.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
NewsBot
Dec 28, 2014 06:20 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
Mad_Ice
Jul 29, 2002 09:44 PM
Manaz101
Jul 18, 2002 09:39 AM
