question on jet hots
Old Feb 5, 2005 | 08:37 PM
DiabloGT's Avatar
do jet hots have air and egr hook ups? if they do, do they fit just right?
thanks
Old Feb 5, 2005 | 08:41 PM
NVetro's Avatar
Re: question on jet hots
You specify that when you call jet hot to order them. I ordered my long tubes from jet hot with out EGR or AIR connections, with EGR and AIR connections they are going to charge you alittle more. But you can get them either way.
Old Feb 5, 2005 | 08:44 PM
DiabloGT's Avatar
do you know if they hook up good?
Old Feb 5, 2005 | 08:48 PM
NVetro's Avatar
My buddy got his jet hot LT's with the EGR and AIR hook-ups and they bolted right back up. I'd delete the EGR/AIR if your not worried about emmisons.
Old Feb 5, 2005 | 08:56 PM
DiabloGT's Avatar
i am worried about emissions, do you think there si a small chance i might pass?
thanks
Old Feb 5, 2005 | 09:02 PM
NVetro's Avatar
With long tubes...ehhhh, i dont think so...not to sure actually. I am not worried about it, so i never investigated it. I guess its how clean your motor runs and if your running cats or not. If you dont fail on emmisons you mite faile on db level
Old Feb 5, 2005 | 09:05 PM
DiabloGT's Avatar
do they all do db level?
http://www.vehicletest.state.ma.us/autotestproc.html
can someone check this page for me and ssee if they check db level or not?
thanks
Old Feb 6, 2005 | 01:20 AM
dover179's Avatar
thanks
Looks to me like they just plug into the PCM and check for codes and see that everything's working fine. As far as the headers go, looks like they'll do a visual inspection and, depending on how strict they are, it might not pass just because they are long tubes (emissions or not). Might get away with shorties or maybe mids. If they're leanient, you'll be ok with them as long as you have the emissions hooked up and still have 2 cats.
Old Feb 6, 2005 | 11:18 AM
ShawnMacAnanny's Avatar
He has a 1995. OBD1 they won't check your car that way. He has to pass with 100 ppm HC and .6% CO.
LT14LIFE
Feb 9, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
RedLineRev
Jan 23, 2003 03:51 PM
ferraricameron
Jul 29, 2002 07:46 PM
