Which O-rings are for the W/P drive?
Old Feb 6, 2005 | 11:47 AM
utahbound's Avatar
I got a full gasket set from the machine shop and I am finishing up assembling the motor. Besides the o-rings for the injectors, I have 5 O-rings. Of these, there are two matching pairs, both of which appear to be the correct diameter for the drive. Here are some measurements I took of each of these pairs of o-rings.
Set 1:
Outside diameter: 1/2"
Thickness of O-ring: 3/32"
Set 2:
Thickness of O-ring: 1/16"
Which of these are the correct o-rings for the water pump drive?
Also, what is the bolt hole on the driver's side of the engine block, just forward and above the rear freeze plug? I don't think it is a sensor and it's been a few months since I pulled the motor.
Klypto
Mar 23, 2016 09:05 AM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
grgguy
17
Feb 23, 2015 07:57 PM
jb4xx
Feb 2, 2015 10:00 PM
