Question about Vacuum.
Old Nov 23, 2003 | 10:13 PM
  #16
onebadponcho's Avatar
How tight did you set your valves past zero lash? If they're too tight, your valvetrain will be quiet but your valves won't close all the way; thus possibly causing your low vacuum and lack of power. Just taking a stab because no one else mentioned it yet.....
Old Nov 23, 2003 | 11:06 PM
  #17
LT1ponykilla's Avatar
Actually I did have a rr on #1 that was too tight and cause 0 compression on that cylinder. That was the only one that showed a miss on the scope at the dealership. I got that fixed and just did the vacuum test yesterday and found out it was low.
Old Nov 24, 2003 | 11:52 AM
  #18
94 NO TOP Z's Avatar
Re-do all your rockers... if you had one too tight there might have been others. I pull about 17" vacuum but, have a little smaller cam. I would think yours should pull 15" vacuum.
Old Nov 24, 2003 | 06:37 PM
  #19
Is it strange that even though the vacuum was low, it wasnt stable? It set mainly at 9.5-10 but would sometimes drop down to 8 then go back up to 11. Then set back at 9 for most of the time. Is this normal?
Old Nov 25, 2003 | 07:38 AM
  #20
IslandZ's Avatar
http://www.e-toolbox.com/application...NTAINED.htm#T1
Check out the first graph for interpreting the vacuum gauge.
Old Nov 25, 2003 | 09:49 AM
  #21
I appreciate the link but that text is really hard to read.
Old Nov 25, 2003 | 10:04 AM
  #22
IslandZ's Avatar
If you're using Internet Explorer 6, just hover over the image for a second or two and you should get an image in the lower right corner, click on it and the vaccuum chart will become its original size and be much more readable!
Old Nov 25, 2003 | 10:27 AM
  #23
fastBlack96z's Avatar
Hey I have the same cam as you. I got 15 inches of vacuum at idle. Have you ever run it at Greer?
Old Nov 25, 2003 | 11:44 AM
  #24
Shon Herron's Avatar
Probably not but I do...
Old Nov 25, 2003 | 06:10 PM
  #25
Nah, never ran at Greer.
I just emailed you. Try to check out www.scfyb.com.
Old Nov 25, 2003 | 06:23 PM
  #26
Whats up Shon. Remember me I bought the bbk headers from you.
Old Dec 1, 2003 | 08:44 AM
  #27
Yeah!! How are things going? Got the headers on and more stuff yet?
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
