question about PCV valve...
Old May 25, 2004 | 04:29 PM
jeff2004's Avatar
What do our PCV valves look like? I bought one from wal-mart, a Fram one, and when i took the one off of the car, they are not even close to the same. The one i took of the car was not even a valve, it was just a 90 degree plastic elbow. The part number of the one i got is FV296. Is this the right one?
Jeff
Old May 25, 2004 | 04:31 PM
SWINGRRR's Avatar
Its in the passengers side of the intake, not in the valve cover.
About half way down, looks like a shiny metal tube.
Old May 25, 2004 | 04:34 PM
jeff2004's Avatar
Oh, ok, maybe i'm not looking at the right thing. The thing i pulled off was on the valve cover. thanx for the info!
Jeff
Old May 25, 2004 | 04:51 PM
The PCV valve is in the DRIVER's side of the intake manifold, middle. The line on the passenger side SUPPLIES filtered, MAF measured air to the valve cover so that it can be pulled out through the PCV system.
Thanks to Shoebox:
http://shbox.com/1/pcv.jpg
Old May 25, 2004 | 06:20 PM
Mtrhds94Z's Avatar
AC Delco CV895C or Fram FV 296 is correct..
Old May 26, 2004 | 12:50 PM
96LT1Fan's Avatar
Here's a bit of a heads up on the Fram PCV filter. I installed one last week. It didn't seem to fit as snugly in the rubber grommet as the OE piece. I think I was actually getting a little bit of a vacuum leak around the FRAM, my idle shot up to about 2000 rpm. I went back and wiggled the PCV filter hose, the leak subsided dramatically. I think I'm going to pick up an AC Delco.
Old May 26, 2004 | 12:56 PM
Patman's Avatar
Question for those of you with traction control:
how the heck do you change the PCV valve? The darn TC unit is in the way!
Old May 26, 2004 | 01:02 PM
Cahill93Z's Avatar
whats thing that's at the end of the passenger valve cover? Mine leaks oil i put a new rubber grommet on it but it still seeps out what can i do?
Old May 26, 2004 | 01:36 PM
That is simply a hollow plastic elbow that allows the hose from the throttle body to connect to the valve cover. A trace of oil around the grommet would be somewhat normal. A large amount of oil might indicate a problem. That would be the result of excessive crankcase pressure. That could be caused by a plugged PCV valve, or by excessive piston ring blowby.
In theory, the line from the TB supplies the air to the valve cover, and thats the air that the PCV system pulls through the crankcase and lifter valley to remove the contaminants that build up in there. In the event of excessive crankcase pressure, the pressure vents backwards from the valve cover to the TB, and is pulled into the intale manifold to be burned. Pull the hose off that goes between the TB and the valve cover. Look for oil in there. Then pull the top cover plate off the TB.... that's where the oil mist ends up when you have excessive crankcase pressure. After that area get filled up, the oil gets into the front of the TB, and starts to carbon up the TB and the intake manifold.
Worth looking to see if you have signs of excessive blowby.
Old May 26, 2004 | 06:16 PM
Cahill93Z's Avatar
thanks
HectorM52
Jul 30, 2017 11:46 AM
lt1matt
Mar 21, 2015 07:35 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
grgguy
17
Feb 23, 2015 07:57 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
