question about new LCA's
Old Apr 17, 2004 | 11:11 AM
scoobysnax83's Avatar
I just put some new LCA's on my Z and now everytime I hit the slightest bumps they make a tap sound. I put a little grease on each one before installing them. What is the cause of this and will it stop after awhile? Thanks...
Old Apr 17, 2004 | 03:33 PM
JD30thZ28's Avatar
Do they have poly bushings? or are they spherical ends? The spherical will always make that slight ticking noise, if it is the poly bushings, make sure the bushings are fine and that there is no metal to metal contact between the lca and mounting area.
Old Apr 17, 2004 | 04:33 PM
They do have poly bushings. Now, that I look at it better, I don't think that I was supposed to grease them up. It looks as though there is surfaces on the end that are supposed to be flush with the chassis and that there is a swiveling mechanism in the center. It seems to be getting better as I drive it though. I think all the grease needs to be removed from them, but I'm not sure. Thanks for the help
Old Apr 17, 2004 | 04:42 PM
They SHOULD be greased, using the correct grease for polyurethane. The ES poly's come with little tubs of white, water-resistant grease, and the best thing you can do is slather it all over the bushings.
Check the bolts and make sure they are properly torqued.
Old Apr 17, 2004 | 04:49 PM
Cmr0z28's Avatar
I loaded mine up w/grease...no problems. Did you torque down the LCA bolts when the suspension was loaded or while the rear was hanging?
Old Apr 17, 2004 | 04:51 PM
I did it while it was hanging, should I tq them while loaded? Also, I didn' t think that there was a tq spec on them or that it was that necessary. Does anyone know the tq spec?
Old Apr 17, 2004 | 05:01 PM
Cmr0z28's Avatar
Pretty sure it's around 80 ft-lbs.
There's your problem right there....go loosen the bolts, hand tighten them, jack up the rear (or you can just do it on the ground) and torque them down with the suspension loaded. Mine did the same thing until I did this and I'm 99.99% positive it's going to work for you.
Old Apr 17, 2004 | 09:37 PM
thanks, I'll try that and post up the results in the morning
Old Jul 4, 2004 | 11:58 AM
Hyperspeed97z28's Avatar
did this ever work for you ???
Old Jul 5, 2004 | 11:13 AM
it did for about a month. It drives me crazy and I wish I had never changed them...
lbrowne
Nov 13, 2011 04:25 PM
Brad 97z
Aug 10, 2002 09:58 AM
Trevor98ramair
Jul 31, 2002 02:43 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
