putting stock injectors back in?
Old Nov 6, 2004 | 12:01 PM
94zrag's Avatar
Is it safe for me to run my stock injectors for a week or two, while I wait for my new set to get here? Would the motor run to lean or not?
Old Nov 6, 2004 | 01:24 PM
sssalah's Avatar
Re: putting stock injectors back in?
If you use it for normal driving and ss long as you don't rev it to the sky and keep the duty cycle within range you'll be safe. Just don't rev it past 4k.
Old Nov 7, 2004 | 09:30 AM
What size injectors has your PCM been reprogrammed for? If it was programmed for anything significantly larger than stock, you could end up running extremely lean, beyond the limits of the PCM to adjust using the long term fuel corrections.
spearous
Jan 12, 2015 11:03 AM
97SSdude
Dec 31, 2014 07:43 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
Brent94Z
Mar 21, 2002 04:44 PM
