Putting engine on stand.. ?
Old Apr 21, 2005 | 08:11 PM
96ta(nick)'s Avatar
Where can i hook the chains up so i can pull the motor off the kmember to put the engine on a stand? I don't want to put them somewhere that won't support the weight..
Old Apr 21, 2005 | 09:04 PM
94zgreenmachine's Avatar
Re: Putting engine on stand.. ?
I used (2) 5/16 bolts, bolted to the lifter galley where the spider plate bolts to.No problem. Just do not go bouncing the engine all over the place and you'll be fine. If your chains are long enough use the motor mount bolt holes. Use the two hole that seem to be sorta criss-cross from each other. You won't find two holes in the center but they are offset each other in the center and it will lift the engine almost perfectly centered.
Old Apr 22, 2005 | 06:07 PM
96ta(nick)'s Avatar
So it will hold it fine in the center under the intake?
Old Apr 22, 2005 | 06:12 PM
396D1SS's Avatar
There is a bolt hole on the back of the passenger side head and hook the other side to the coil bolt
Old Apr 22, 2005 | 08:32 PM
Yes, but you'll need some slighty longer bolts to maximize the number of threads. Yo could also use the bolts in the heads in the above post. Either way will work fine.
DirtyDaveW
Dec 1, 2016 05:37 PM
PCLZ28
Dec 24, 2015 05:19 PM
Jan 5, 2015 07:14 PM
Injuneer
Dec 15, 2014 09:36 AM
Jul 4, 2005 05:00 PM
