Putting engine on stand.. ?
Where can i hook the chains up so i can pull the motor off the kmember to put the engine on a stand? I don't want to put them somewhere that won't support the weight.. :confused:
Re: Putting engine on stand.. ?
So it will hold it fine in the center under the intake?
There is a bolt hole on the back of the passenger side head and hook the other side to the coil bolt
