Pushrod Question
Old Dec 21, 2005 | 06:22 PM
Harvey's Avatar
Question Pushrod Question
Is it extremley important to put the pushords (stock pushrods) back in the same excat place they were pulled out? Shoebox's website, which is like everyone says awesome, says "Remove the pushrods, keeping them in order if you will reuse them." How important is this and what could happen if you don't?
Wayne
Old Dec 21, 2005 | 06:45 PM
67stang96formula's Avatar
Re: Pushrod Question
I dont think its that imporatant i cant see how it would hurt to put them in different spots.
Old Dec 21, 2005 | 08:11 PM
OBE1 95Z28's Avatar
Pushrods can be moved around. If you're going to use the same cam, I'd put the same lifter in the same place. Not as big an issue with roller style lifters as it is with non-roller style.
Old Dec 21, 2005 | 08:23 PM
RICEFEDZ28's Avatar
It's fine to move pushrods around.
Old Dec 21, 2005 | 09:27 PM
Harvey's Avatar
Allrighty. I didn't see why it would hurt, but I do treat Shoebox's tech site like the LT1 Bible, so I just wanted to be sure it was okay. Thanks for the peace-of-mind.
OBE1 95Z28, if you upgrade to a larger cam and are using the same lifters, does it make any difference then on which lifter goes where?
Wayne
Old Dec 22, 2005 | 09:50 AM
OBE1 95Z28's Avatar
With a new cam it doesn't make any difference. The reason for matching is to "line up" any wear patterns between mating parts. Since the cam is new, there aren't any wear patterns.
Old Dec 22, 2005 | 10:28 AM
rskrause's Avatar
Moderator
Maybe it's a carryover from the old flat tappet days, but I like to put valve train parts back where they came from.
Rich
Old Dec 22, 2005 | 10:34 AM
Rich
Only a few of us are old enough to have picked up that habit.....
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
armedtrigger
Feb 24, 2015 08:30 PM
alex5366
Feb 17, 2015 08:12 PM
Jul 4, 2005 05:00 PM
