Pulling codes
Old Oct 25, 2005 | 03:12 PM
Sgt_Morrow's Avatar
Pulling codes
How can i check the codes on my 95 z28
Old Oct 25, 2005 | 03:40 PM
Chris 96 WS6's Avatar
Re: Pulling codes
With a scan tool.
Old Oct 25, 2005 | 04:01 PM
moparman's Avatar
Re: Pulling codes
The '95s are OBDI with an OBDII connector under the dash. You'll need either a code puller or scan tool for OBDI with the OBDII connector cable.
Old Oct 25, 2005 | 04:03 PM
Jps 1LE's Avatar
Re: Pulling codes
Get a scan tool from www.akmcables.com. Then you will need a laptop to hook it up to. And also you will have to buy or download a program to scan it. You can go to www.carputing.com and download their free program called pcmcomm.exe and you can use that to scan for codes. Or do a search on here and look for freescan. Either of the two work.
Just remember you have a 1995 Z28. This is an OBD-I computer but requires an OBD-II connector for the cable
Jp
Old Oct 25, 2005 | 09:13 PM
moparman's Avatar
Re: Pulling codes
Here's where you can buy refurb scan tools at a good price: www.autocheckup.net/ You need the XP240 with 16 pin cable for a '95, or the XP240 Pro Pack, but it looks as if you have to buy the correct cable to use it on a '95.
Old Oct 26, 2005 | 11:34 AM
Sgt_Morrow's Avatar
Re: Pulling codes
Thanks guys
lt1matt
Mar 21, 2015 07:35 PM
Fatdog2
Feb 13, 2015 08:19 PM
Gtpguy
Jan 26, 2015 04:50 PM
91Bird305
Aug 5, 2002 01:39 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
