383 vs 396
Old Oct 26, 2005 | 12:32 AM
97silvermaro's Avatar
383 vs 396
i see a lot of 383's when it comes to a bottom end rebuild... how come the 383's are more popular than the 396's?... hows that old saying go? theres no replacement for displacement
Old Oct 26, 2005 | 02:36 AM
SS RRR's Avatar
Re: 383 vs 396
I used that handy little fellow called the "search" button and lookie what I found!
http://web.camaross.com/forums/showt...hlight=383+396
... and that's from merely copying/pasting your title.
Bunches of info/experience and opinions on this subject. Use at your disgretion.
Old Oct 26, 2005 | 07:15 AM
LameRandomName's Avatar
Re: 383 vs 396
Short answer is that the extra 13 cubes = cubic $$$$.
383 is a better VALUE.
Old Oct 26, 2005 | 07:48 AM
sssalah's Avatar
Re: 383 vs 396
A good forged 396 rotating assembly is going to cost the same as a 383 or 355. The main advantage to a 383 over a 396 is the availability of large varaity of parts from all manufacturers
Old Oct 26, 2005 | 11:53 AM
Turbo6's Avatar
Re: 383 vs 396
No, the 396 will cost more. What you have to realize is that the rotating assembly cost is not the only cost. You have machine shop costs for clearancing, then you need a smaller base circle camshaft, then you sometimes need different, more stroker clearanced rods, then you need different rod bolts that will clear the cam and block rails. These are just a few examples of the things that often aren't thought about.
Old Oct 26, 2005 | 12:00 PM
rskrause's Avatar
Moderator
Re: 383 vs 396
Ye Olde Search Function is, indeed, your friend! The 383 is probably at the "sweet spot" in terms of cost/hp potential.
Rich
Old Oct 26, 2005 | 12:17 PM
Z28SORR's Avatar
Re: 383 vs 396
Which equates to lower cost.
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
