Props to AI!!
Old Mar 12, 2007 | 07:22 PM
  #16
Loadre's Avatar
Who built your TH350? I bought a built one off a guy but I'm wondering who to take it to after it bites the dust.
Old Mar 12, 2007 | 11:03 PM
  #17
rje's Avatar
rje
Guys there has been a development. I said in an earlier post that I would be swapping out to a tighter converter tonight, well as it happens I didn't change converters I changed gears to 4.10's because I found a tooth broken off my 4.88's. I don't like to make but one change at a time so it looks like I'll be giving it a go and see what the taller gears will do for me. I'll keep posting results.
Loadre, my trans was built by Hughes Performance in Arizona.
Randy
Old Mar 13, 2007 | 09:23 AM
  #18
Z-RATED94's Avatar
Nice times, I'm jealous!! But won't the 4.10s make the stall rating even higher?
Old Mar 13, 2007 | 10:08 AM
  #19
rje's Avatar
rje
It probably will but I didn't really have a choice, because last night was the only time that I had time to work on it, and besides I was planning on swapping gears later anyway. Now I still will probably need to swap converters, but that will be next week.
Randy
Old Mar 13, 2007 | 09:32 PM
  #20
96capricemgr's Avatar
Never seen a car make it's fastest pass first night out, think the next couple months will be interesting.
Old Mar 13, 2007 | 09:42 PM
  #21
mdacton's Avatar
I would think with that 4500 and the 4.10 from a 88 its probly going to walk up top pretty good......
Old Mar 13, 2007 | 10:38 PM
  #22
rje's Avatar
rje
I talked to Hughes Performance today about what converter to use and they said definitely use the 3500. So I'm going to try and work my schedule so maybe I can put it in on friday night and be ready for testing saturday. I really think that converter will make alot of difference and allow the car to run much closer to it's potential, then maybe another gear swap to a 4.33 pro gear and it should be on the money. I'll keep everybody posted. Later.
Randy
Old Mar 14, 2007 | 12:43 AM
  #23
SS MPSTR's Avatar
Randy
Good luck Randy - I can't wait to hear how the car responds to the TC and gear swap. That thing should be a bullet.
Old Mar 17, 2007 | 12:53 AM
  #24
rje's Avatar
rje
I got the 3500 converter in tonight and took care of a few other problems that I found. I was really looking forward to putting up some good numbers tomorrow, but I guess it will have to wait, my track cancelled there TnT because of excessive rain. Oh well, when I get to the track I'll post my times.
Randy
Old Mar 22, 2007 | 10:56 PM
  #25
rje's Avatar
rje
The forecast looks great so hopefully I can put up a big number tomorrow night.
Randy
Old Mar 23, 2007 | 11:21 AM
  #26
foggedz's Avatar
Where does your motor make peak TQ numbers. I would bet its close to if no higher than 5000RPMS. Why would you want to go with a 3500 converter?
Old Mar 23, 2007 | 11:29 AM
  #27
rje's Avatar
rje
The reason is because the 4500 flashed to 6000+ and even if the tq peak is 5000 it still way past it. The 3500 should flash between 4200-4500 allowing the motor to pull through the tq peak instead of flash past it, therefore allowing more power to get to the ground.
Randy
Old Mar 25, 2007 | 11:31 AM
  #28
rje's Avatar
rje
Here's the update guys. It looks like the gear change to 4.10 that I had to do because of my broken 4.88 killed my 60ft and made the new converter to tight. It still ran a 6.89 @ 99.5 mph, but only with a 1.50 60ft and in 88 deg weather. I just ordered a new set of 4.88's and if that still doesn't put me exactly where I want to be I may go to my 4000 converter, but from what I've seen with the right gear/converter the car should run 6.60's maybe even 6.50's @ 102 mph in decent air. I'll post the results of the gear change as soon as I get to the track.
Randy
Old Mar 25, 2007 | 11:42 AM
  #29
tireburnin's Avatar
Randy
6.8s is still bad ***. Gears and converter should make quite a difference once they are optomized. I hate changing converters though, so I don't envy you a bit!
Old Mar 25, 2007 | 01:59 PM
  #30
jasonisdn's Avatar
thats still great. to know that you can hack off that much more et , is even better. congrats.
