Props to AI!!
Old Mar 25, 2007 | 02:08 PM
  #31
speed_demon24's Avatar
100mph in the 1/8th is flying, are you going to run at the 1/4 too or just 1/8th? Keep us updated on the times.
Old Mar 26, 2007 | 07:42 AM
  #32
SS MPSTR's Avatar
Great job, Randy. Once that 'verter/gear is worked out it will easily see 6.5's.
Old Mar 26, 2007 | 08:00 AM
  #33
Javier97Z28's Avatar
Moderator
Nice job! Glad to see alot of LT1 combos coming together finally.
Especially with LT1 intakes instead of single planes.... not that there's anything wrong with single planes but y'know..
Old Mar 26, 2007 | 11:46 AM
  #34
foggedz's Avatar
Originally Posted by rje
The reason is because the 4500 flashed to 6000+ and even if the tq peak is 5000 it still way past it. The 3500 should flash between 4200-4500 allowing the motor to pull through the tq peak instead of flash past it, therefore allowing more power to get to the ground.
Randy
This is what I thought you were getting at. If you had a converter that flashed to 4500 that was made for your old combo, it will flash higher once you start making more power. Changing the weight of your car will also affect how high the converter will flash.
If you want a converter to flash to 4500 you should have a 4500 converter made for your power and weight setup.
I have found that with a th350 more stall is needed because of the taller first gear. With a 3200 stall in my cam only lt1 I could not get out of the 1.7 range. I had the converter restalled to 4000, and the car went in the 1.5s
Old Mar 26, 2007 | 02:18 PM
  #35
rje's Avatar
rje
I know and understand what you are saying and believe that my upcoming gear change will help thing alot, and if it's still not enough I can always go to my 4000 converter.
Randy
Old Mar 30, 2007 | 03:20 PM
  #36
rje's Avatar
rje
I got the new set of 4.88 gears in last night, but I won't be able to get to the track this weekend because of a death in the family. Hopefully next week I'll have sone new times to post.
Randy
Old Mar 31, 2007 | 11:08 AM
  #37
marshall93z's Avatar
Cool.
Sorry to hear about the death.
Old Mar 31, 2007 | 06:33 PM
  #38
flyinZ's Avatar
I just saw this topic and am interested...Why is it called the "Dominator" 200cc H/I??
How radical is that cam also?
Old Apr 1, 2007 | 03:54 PM
  #39
rje's Avatar
rje
You'll have to call and ask either Ron or Phil about the name. All I know is that was waht was on my bill, and not to mention they make the car fly. The cam 24x/25x @0.050 with .600+ lift int/exh.
Randy
Old Apr 1, 2007 | 04:00 PM
  #40
mdacton's Avatar
what do you use to control the engine?
Old Apr 1, 2007 | 10:31 PM
  #41
rje's Avatar
rje
The stock GM PCM for right now, but as soon as I get the money I plan on getting either an Accel Gen 7 or a FAST XFI. Then I'll probably go with a larger cam and really spin the motor.
Randy
Old Apr 5, 2007 | 12:22 PM
  #42
rje's Avatar
rje
I'll be heading to the track Sat, the weather is supposed to be cold, so hopefully I can put up some good numbers.
Randy
Old Apr 17, 2007 | 11:34 AM
  #43
rje's Avatar
rje
Well guys more bad news, I busted the 2nd gear sprag in my tranny, but it did run a 6.83 @ 99.71 mph before it did. I also noticed that my slicks were worn completely out and to run the 83 with only a 1.51 60ft, so I felt OK about that. I believe I need just a little bit more converter so while I'm fixing the tranny I'll slip the other converter in and throw on a new set of slicks. Maybe this weekend everything will come together finally. I'll keep things posted.
Randy
Old Apr 17, 2007 | 02:58 PM
  #44
jasonisdn's Avatar
Randy
t56rebuilds.com has a 2 week turn around right now, i just ordered mine. hate to see your tranny go but its better than the motor dieing.
Old Apr 17, 2007 | 03:46 PM
  #45
rje's Avatar
rje
Don't feel to bad for the tranny, it was a Hughes TH350 that had 5 1/2 yrs of racing abuse on it, so I think it did alright, and besides if I hadn't put that tighter converter in it it probably wouldn't have busted the sprag cause all the clutches and banbs look like new.
Randy
