Proper Oil Level in Canton 242-T pan
Old May 5, 2008 | 11:37 AM
cehan's Avatar
I've seen different opinions about the correct oil capacity when running a Canton 242-T pan...6 qts., plus the extra amount in the filter, or 6 qts. minus the extra amount that's in the filter.
I'm replacing my Melling oil pump with one of Melling's select pumps, so while the pan is off I checked it by filling it up with oil. When I put in 5-1/3 qts. (about what's left after filling the filter) the oil level is exactly even with the bottom of the windage tray. So it looks like 6 qts. minus what's in the filter is the answer.
Old May 5, 2008 | 12:22 PM
1989TransAm's Avatar
You can. One thing a bigger oil pan can do for you is get the oil further away from the crankshaft. I think you need a minimum of 5 quarts including the filter. That is what I'm running in my 6 quart oil pan.
HectorM52
Jul 30, 2017 11:46 AM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
