Proper Oil Level in Canton 242-T pan
I've seen different opinions about the correct oil capacity when running a Canton 242-T pan...6 qts., plus the extra amount in the filter, or 6 qts. minus the extra amount that's in the filter.
I'm replacing my Melling oil pump with one of Melling's select pumps, so while the pan is off I checked it by filling it up with oil. When I put in 5-1/3 qts. (about what's left after filling the filter) the oil level is exactly even with the bottom of the windage tray. So it looks like 6 qts. minus what's in the filter is the answer.
JasonD
Aug 23, 2010 03:14 PM
JasonD
Jul 27, 2002 08:57 PM
