Problems with installing Hooker catback
Old Dec 31, 2004 | 09:32 AM
94zLT1's Avatar
so after installing my hooker catback on my 94Z i see a few problems..first off the "I" pipe hangs down pretty low..2nd,the over the axle pipe just about touches the axle/crossmember (you can feel it at idle)...3rd when using the hanger (thats right they only gave me 1) the muffler touches the heat shield for the tank..4rth..thus the tips do not exit straight or correctly..5th i took it to a muffler shop and they said to take it back b/c it doesnt fit right..6th..im pissed
this happen to anyone else?
Old Dec 31, 2004 | 12:08 PM
94zLT1's Avatar
Re: Problems with installing Hooker catback
what kind of material can withstand heat of a direct exhaust pipe and cushion a metal to metal contant so there is no sound/vibration?
Old Dec 31, 2004 | 01:16 PM
Spinner's Avatar
Take a band clamp, loop it through the bottom coil, and clamp an old valve spring in between the pipe and the chassis.
Old Dec 31, 2004 | 01:53 PM
stereomandan's Avatar
Sounds like you need to get back under there and do some adjustments. I did pry a couple pieces of sheet metal out of the way to make mine clear. Mine was rubbing near the top of the "over the axle" portion though. Once the drivers side hanger is installed correctly, you can control the height of the muffler by raising and lowering the exhaust tip. It kind of pivots on the drivers side hanger portion.
They do fit pretty well, you just need to get everything connected just right. The drivers side hanger is very important. Also, I welded a piece of metal in the passenger side hanger area to raise up that hanger. It helped the I-pipe easily clear the axle.
Dan
Old Dec 31, 2004 | 03:45 PM
blackztpi's Avatar
maybe they sent you one for the wrong year or something???? i have a 94 6 speed and it took me about 45 minutes (including multiple trips to autozone to buy different clamps) to get the the catback on and working. inever had a problem with it touching anything. best thing to do is to take it all off and start all over again. it's not very time consuming
Noenav
Mar 1, 2019 07:38 AM
ModdedNerd
Jan 1, 2015 10:56 AM
97SSdude
Dec 31, 2014 07:43 PM
thenewkid
Nov 27, 2014 09:41 AM
GigaMp3z
Feb 20, 2003 02:57 PM
