Putting a gear drive on a LT1
Old Dec 31, 2004 | 10:23 AM
(White Lightning)'s Avatar
Question Putting a gear drive on a LT1
I know that you can do this, but i'm just making sure that i'm doing everything right. I have a 93 engine, so that means that i need a electric water pump a 95-97 timing cover, and a 95-97 vented opti spark. Thats all I need
I have all execpt the timing cover and the water pump. I'm going to buy the water pump from NAPA but I'm in the need for a cheap timing cover. Please Help
Andy
Old Dec 31, 2004 | 12:00 PM
Re: Putting a gear drive on a LT1
When a "topic" has "LT1" in it, most likely it belongs in "LT1 Engine Tech". I know this topic has been discussed there, and you should be able to find it with a "search".
Moving to LT1 Engine Tech.
Old Dec 31, 2004 | 02:28 PM
mongse_1's Avatar
Knock sensors aren't big fans of gear drives.
Old Dec 31, 2004 | 03:50 PM
I'm sending my pcm out to pcm for less so that wont be a problem
PCLZ28
Dec 24, 2015 05:19 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Elcojoe
Nov 17, 2014 10:27 PM
1LEThumper
Jul 14, 2003 12:45 PM
