Problems with cc305 cam install
Old Oct 28, 2004 | 07:30 PM
  #76
meangrn94ta's Avatar
Re: Problems with cc305 cam install
or just call when you get into town.
Old Oct 28, 2004 | 07:36 PM
  #77
hey med,
plugs are brand new, the opti was already replaced with a functional unit that was used, and the wires are new as well. i have put a new feul pump in the car and it ran better for a couple of days and started up as soon as it got to the track. this all start of the cam install. i bought a msd digital 6 plus but i dont want to put it on before i figure out what this problem is cause the msd might just be a bandaid fix for the real problem or could just cause more problems. what do u think.
Old Oct 28, 2004 | 07:56 PM
  #78
med_reject's Avatar
I cant localize where the prob is, but if it revs freely, and only misses under load, then this means it pretty much has to be fuel or spark delivery. Either that or air is nto getting in or not being sensed properly when it goes into the motor in higher volume. Try borrowing a buddy's maf sensor??
Old Oct 28, 2004 | 08:06 PM
  #79
well i have unplugged the maf so that the car would run on an open loop (i think that is how it works) and the same probblem still exsisted. i have a msd blaster coil on it and i even replaced that with a functional one off a friends car and it still had the miss.
Old Oct 29, 2004 | 05:18 AM
  #80
ttt
Old Oct 29, 2004 | 08:01 AM
  #81
IslandZ's Avatar
Just a thought, but the MAP sensor will calculate the load on the engine by means of vacuum, maybe if you tried to replace this it would work?
Old Oct 29, 2004 | 09:55 AM
  #82
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
i will sacrifice a chicken for you tonight. man tuff problem. good luck.
david
Old Oct 29, 2004 | 03:40 PM
  #83
the map sensor is the black one on the intake that sits to the left side of the intake if you are looking from the front of the car. its black with a green plug in correct? i didnot replace it but i cleaned it.
Old Oct 29, 2004 | 05:05 PM
  #84
FlyboyZ28's Avatar
Yep thats the one.
http://shbox.com/1/map.jpg
Old Oct 29, 2004 | 05:18 PM
  #85
thanks
Old Nov 4, 2004 | 05:49 PM
  #86
well after i replaced the plugs and gaped them at .035 and bumped the fuel pressure down it had a slight miss them this last sat. i took it out and the miss was gone great right. so i took it to the track and no miss but insted of shifting at 6200 it goes to 6500 at just say there and it feels like the tranny is slippin really bad or i'm blowing the tires off and wont shift. but its not boucing of the rev limiter, its like i'm stallin it up that high. when i do my burn outs (with et streets) as i come put of the burn out box it used to throw me back in the seat when it cought but, not this time it just feels like it's spun the whole time. a friend at the track thinks i rolled a sprag in the converter hell its a stocker anyway but i think the tranny is shot. what do u guys think. well if it is shot im putting the turbo 350 in it with a brake.
Old Nov 4, 2004 | 11:10 PM
  #87
dren70's Avatar
i had the same problem with a turbo 350 years ago. it would rev high and not shift. tranny place said they couldn't even rebuild it and i should just put in another one. of course they wanted to make the sale though sooo....
david
Old Nov 4, 2004 | 11:25 PM
  #88
FlyboyZ28's Avatar
Why doesnt anyone trust built 700r4's or 4l60e's
Old Nov 5, 2004 | 04:10 PM
  #89
so dren you think its the tranny too.
daniel know one trusted the 4L60E's cause not many people can build them right and strong enough to hold what you throw at them. well i should say not many people areound here in e-ville.
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
