problem with my 95 z28 can anyone help?
im not sure if this is a fuel problem or a spark plug problem.but my car is starting to hesitate,i try to take off and the car dies down(doesnt die completely but bogs down then takes off)and when i drive it jerks alittle.but when its warm it doesnt do it as bad.if anyone can help with this all i can say is thanks soooo much.by the way the car has 122,000 miles on it if that matters at all...thanks for yor time
You might want to try the "search" feature. "Hesitation" is probably the most frequently discussed topic on this forum. There are NUMEROUS possible causes and NUMEROUS possible cures. There are a couple of threads that go on for pages with discussion. And there have been a large number along the lines o "solved my hesitatin problem".
You also might want to provide some info on the car... general condition, have the plugs, wires, distributor, etc. ever been changed, what modifications. That might help get an answer.
Good luck!
Good luck!
Well, it could be one of many things. Air, fuel, ignition...leaks, sensors, filters you name it.
At least I can share what my stumble problem was, it occured on low rpm at load...I measured the plug wires which were ok, and I changed the plugs but it was still there.
It turned out to be a bad plug wire anyway, I cind of noticed it when the plug wire separated from the plug boot when I wiggled it a bit
So I would start with checking the wires and the plugs...but that's me.
Hope you get it solved.
i havent replaced anything yet but im gonna have it looked at this weekend but i have no clue where to have them start plus i dont have the cash to fix things that dont need to be replaced i just want it to run right again
slothgrant
Aug 22, 2002 03:01 PM
