Powerband on Hot Cam???????
Old Aug 10, 2003 | 03:25 PM
S.J.S.'s Avatar
Anyone know the powerband range for the GM Hot Cam? Need to figure out what torque converter to go with.
thanks.
Old Aug 10, 2003 | 03:29 PM
Camaro_Maniac63's Avatar
GM claims 3000-6500rpm....
Old Aug 10, 2003 | 03:31 PM
Cmr0z28's Avatar
go with a 3000 stall
Old Aug 10, 2003 | 03:47 PM
Ken95Z28's Avatar
I had pretty good luck with the 3500 stall when I had my HotCam.
Old Aug 10, 2003 | 03:50 PM
tryme96Z's Avatar
m6 conversion!
Old Aug 10, 2003 | 04:27 PM
S.J.S.'s Avatar
then why does everyone say for streetability go with the hot cam??? Wont the 3000 stal be crappy for everyday stop and go driving????
Old Aug 10, 2003 | 08:04 PM
S.J.S.'s Avatar
ttt
Old Aug 10, 2003 | 08:10 PM
94 CAMRO Z28's Avatar
With stock heads mine seems to pull pretty good up to 6300 or so.
Aaron
Old Aug 10, 2003 | 08:14 PM
FastZinTennessee's Avatar
I have the HOTcam, and ported heads with larger valves..... With a 2800 stall I'm pulling 1.8X short times on drag radials, that should be good enough for ya, and the 2800 stall is ok for daily driving.
John
Old Aug 11, 2003 | 04:59 AM
S.J.S.'s Avatar
but if the powerband is from 3000 to 6500 your stall gotta be at least 3000.
Old Aug 11, 2003 | 08:30 AM
If you want to get technical about it, I think you are supposed to pick your stall so that it's about 400 RPM below your torque peak.
John
Old Aug 11, 2003 | 08:47 AM
94formulabz's Avatar
John
I wouldn't really say that is getting technical about it. Torque curves look different for different types of motors. That is just a rule of thumb. According to that I'd pick a 1700 stall for my car, i don't think so.
Gregg 97Z has a hotcam dyno with stock heads. I'd ask him to see it. I used to have it but can't find it.
Old Aug 11, 2003 | 12:29 PM
Well most people don't try and match their converter to their stock cam. Most likely you would match the converter to some cam you would like to install in the future.
Old Aug 11, 2003 | 01:00 PM
GREGG 97Z's Avatar
Here's my hotcam dyno numbers. The spikes after 5300 were due to knock I was getting from a vibration in the catalitic converter (I'm pretty sure) which is now fixed. I was using a stock 3" cat at that time which is now gone, I've replaced it with an ORP/cutout.
jj_burchiel
Mar 5, 2015 07:05 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Aug 4, 2002 06:11 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
