power steering
Re: power steering
Re: power steering
Almost sounds like something in the system is blocking flow. It is possible the flow was blocked and the resulting high pressure is what caused your old pump to spray fluid everywhere?
Re: power steering
Never experienced that particular problem. The manual indicates:
SYMPTON (sic): Hard steering of lack of assist, especially during parking:
POSSIBLE CAUSES:
Brake applied while turning wheel
Damaged or worn steering gear coupling shaft
Sticky flow control valve
Insufficient pump pressure
Excessive internal pump leakage
Excessive internal steering gear leakage
POSSIBLE CAUSES:
carguyshu
Jan 22, 2017 11:19 AM
FMFRacing88
May 25, 2015 08:08 PM
mspennyhughes
Mar 1, 2015 03:50 PM
