power steering
Old Feb 20, 2013 | 12:22 PM
  #16
Re: power steering
Originally Posted by johnboyz28
kevhogaz do i do what you suggested with the wheels off the ground?
Posted from Camaroz28.com App for Android
Did you follow EXACTLY the link that Rob/Shoebox posted? That's right from the factory manual. Maybe it's easier to understand with pictures:
Old Feb 21, 2013 | 01:32 PM
  #17
johnboyz28's Avatar
ok ive done this 3 time by both ways instructed no noise no leaks but still stiff steering ive turned that wheel with wheels off ground bout 100 times ???
Old Feb 21, 2013 | 03:16 PM
  #18
Re: power steering
Almost sounds like something in the system is blocking flow. It is possible the flow was blocked and the resulting high pressure is what caused your old pump to spray fluid everywhere?
Old Feb 21, 2013 | 03:22 PM
  #19
johnboyz28's Avatar
i guess it could be im not real sure where to look though any ideas
Old Feb 21, 2013 | 03:37 PM
  #20
Re: power steering
Never experienced that particular problem. The manual indicates:
SYMPTON (sic): Hard steering of lack of assist, especially during parking:
POSSIBLE CAUSES:
Brake applied while turning wheel
Damaged or worn steering gear coupling shaft
Sticky flow control valve
Insufficient pump pressure
Excessive internal pump leakage
Excessive internal steering gear leakage
Old Feb 22, 2013 | 11:48 AM
  #21
johnboyz28's Avatar
whatever it was it seemed to have worked itself out no leaks or anything thank you for your help
Old Feb 22, 2013 | 02:00 PM
  #22
RamAir95TA's Avatar
Re: power steering
Any chance you have the lines switched by accident?
mspennyhughes
Mar 1, 2015 03:50 PM
