Power Cuts Off At 4k RPM
Old Sep 13, 2003 | 08:09 AM
Hood_Lum's Avatar
Lost to a rice rocket because power was non existant at 4k rpm.
FYI, If your AC/Cruise Fuse is blown you will not be able to make power after 4k rpm.
After losing the race I pulled over changed the fuse and got all my power back. Kinda wierd.
Old Sep 13, 2003 | 10:47 AM
jasons93z's Avatar
power loss up top is usually do to a faulty coil/coil wire. Try that first b/c its cheap
Old Sep 13, 2003 | 12:52 PM
TobyZ28's Avatar
Here were my symptoms: at around 4k when flooring the car ... feels like a 4 banger, doesnt feel like a miss, just reves with little or no power. Shifts hard into next gear though.
Solution: New fuel pump, car had very low Fuel Pressure. Easy check would be to borrow a fuel pressure gauge and see what your fuel pressure is at before you decide to go with coil or fuel pump fixes
rideordie
Nov 5, 2019 04:52 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
97z28k&N
Jan 9, 2015 04:58 AM
XtremeLt1
Sep 13, 2002 08:50 PM
