is it possible to install a LT1 with Hooker LT's already on??
Old Dec 29, 2003 | 10:45 AM
john-e-boy's Avatar
Is it possible to install my LT1 with my Hooker LT's already bolted on to the engine.
I know what a pain it is to install these with the engine already installed and was just wondering if anyone installed their engine with LT's already bolted up.
John
Old Dec 29, 2003 | 10:47 AM
LWillmann's Avatar
I think it will work if you do it from underneath.
Drop the K-member, and mount the motor to it and go at it that route.
Old Dec 29, 2003 | 10:50 AM
BriansZ's Avatar
It would probably be easier if you just had the headers in position when you drop the motor in and then bolt them up.
Old Dec 29, 2003 | 10:55 AM
ibanez6rg's Avatar
I've seen it done dropped in.
john-e-boy's Avatar
I am going in through the top and the only reason I am asking is that I have heard of people having trouble installing a couple of the bolts so I figured it wouldn't hurt to ask.
John
Old Dec 29, 2003 | 11:05 AM
1fast95Z's Avatar
With the engine already out of the car, sounds like a good time to drop on a set of heads and install a cam
Old Dec 29, 2003 | 11:13 AM
carlos64030's Avatar
If you're installing your motor from the top, it would be very difficult to do with the headers attached. I was going to try that, but thought to myself, why complicate things? They'll be easy enough to put on since everything is stripped off of the block.
Old Dec 29, 2003 | 11:27 AM
john-e-boy's Avatar
Yep it was a good time to do a head and cam set up and thats what I did ...
...LT4 heads and intake, Comp cam 306, rockers, all new engine bearings, KB pistons, etc. The only thing oringinal is the block, bore (due to poor machining over here), rods, and crank.
Now just trying to save any aggrivation I can.
John
Old Dec 29, 2003 | 11:30 AM
1fast95Z's Avatar
It sounds like that thing is going to rock!!! You're going to kick a$$ on the autobahn.
Old Dec 29, 2003 | 01:48 PM
LilJayV10's Avatar
John
Whats the part number on the KB pistons? I am rebuilding my friends LT1 in the next month and am looking for reasonablly priced engine kits.
Jason
Old Dec 29, 2003 | 04:05 PM
BAD97SS's Avatar
I installed my motor with the headers on from the top. I have Flp long tubes though. Don't know howw much of a difference with hooker. It was a little struggle but nothing major. I was able to get the bolt nice and tight too, so no leaks. Like everyone else fights about.
Old Dec 29, 2003 | 05:57 PM
john-e-boy's Avatar
I believe the pistons were the hypereutectic model HB106+standard. Thats off the top of my head I will double check tomorrow.
I bought them off someone from the board ($100 new, not bad eigh)and what I have read they are for a 5.7 inch rod in a 350 SBC. I checked the clearance on them and I got plenty of roam even with the CC 306.
The thing you have to be carefull about is the top ring, because they are that hyper.... they have a different ring gap. Their website has more but last time I checked it was down. If you do need the specs let me know I have it saved.
Later
John
Noenav
Mar 1, 2019 07:38 AM
edman
Jan 22, 2015 02:45 PM
ModdedNerd
Jan 1, 2015 10:56 AM
GigaMp3z
Feb 20, 2003 02:57 PM
