possible to hit 10's with a 396 stroker??
Old Nov 16, 2004 | 08:52 AM
detroit1994z28's Avatar
Just like the thread reads is it possible to hit high 10's low 11's on just a 396 stroker. Without a supercharger or nitrous. What kind of combos does anybody recommend to do the job?? I'm looking for a really reall aggressive cam
Old Nov 16, 2004 | 10:10 AM
Turbo6's Avatar
Re: possible to hit 10's with a 396 stroker??
Of course it is possible. It's possible with less displacement than that also. Combo: good heads (AFR 210/220 or fully worked LT4 to keep things simple), fairly large duration camshaft matched to the heads by reputable builder. Decent rotating assembly than can handle the RPM's and then all the accessories (injectors, fuel system, TB, headers, rear end, clutch/torque converter, transmission, driveshaft, suspension, etc). Realistically, you can plan on spending ~$15,000 to get there unless you already have the ancillary things like drivetrain modifications currently. In the end is it worth it to spend the extra to make that kind of power N/A? Not in my opinion (and I've spent it) unless you have a much better reason than bragging rights as motivation for doing it. Your money though.
Do you want an aggressive cam just for the sake of it being aggressive or because you think that is what you need to achieve the goals stated above?
Old Nov 16, 2004 | 10:17 AM
95Bird's Avatar
yes..like said above its very possible to get there. Either make a butt load of power or lighten the car up....or a combination of each. It can be done with the right combo.
Old Nov 16, 2004 | 01:31 PM
This should have been posted in "LT1 Engine Tech". Moving it there.....
Old Nov 16, 2004 | 02:04 PM
neil350's Avatar
Its possible to hit deep 9s in all motor 396 if you wanted an all out motor car.
Old Nov 16, 2004 | 11:58 PM
1racerdude's Avatar
A guy at Thunder went 10.18 N/A with a 396,and it wasn't Joe O.
Old Nov 17, 2004 | 03:37 AM
Fastbird93's Avatar
I would think in an all out motor car that 9's should be no problem if the combination is done right. Shoot, look at Joe O. 9.3's @ 143 all motor in I believe a 388 now.
Old Nov 17, 2004 | 07:07 AM
disco192's Avatar
Joe O has more time and money in that money than most of the people on this board combined. His motor is down to a science.
To hit 10s NA, you would need some badass heads and a FAT cam. I would expect 220+ ports (300+ cfm) plus a solid roller cam in the 250+ range. That would hit 10s easily.
Realistically, I would go with a 383, Lloyd heads, and a solid cam plus some of the bottle. That would be ALOT cheaper and get you to 10s just as easily.
Old Nov 25, 2004 | 05:57 PM
JIMS1999CONVZ28's Avatar
I just got a 'fair' pass with my 383 stroker (93) camaro Z28.
Sixty foot was 1.6? (it spun) with 26 inch tires (too Small), then had to let off the throttle 1/2 down the track as the car started swaying towards the guard rail.
This gave me an 11.5 at 117.5 mph.
With 28" tires and a good launch (1.4 or 1.5) the car should be in the high 10's, no problem
Jim
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
Greg88
Aug 24, 2015 07:59 AM
Cbr02
Aug 23, 2015 10:55 PM
dolfan324
Jul 17, 2015 10:34 PM
