Poly or Poly/rubber for LCA's
Old 05-25-2003, 10:36 PM
96z
96z's Avatar
Im getting the BMR LCA's tues. Do you guys suggest the poly or poly/rubber combo.
What are the pro's and con's of both?
96z is offline
Old 05-25-2003, 10:54 PM
Draco's Avatar
Re: Poly or Poly/rubber for LCA's
If you want to do any autoX or improve handling, stay away from Poly/Poly. You will experience bind as your cars body tries to roll on corners, and the poly bushings refuse to yield. If you get a poly/rubber setup, the rubber will compress as the LCA twists, and you will not have to worry about bind.
If you want to improve handling under hard cornering, go with poly/rubber, or better yet poly/spherical. If you want to go fast in a straight line, poly/poly will have an advantage controlling wheel hop (more traction).
Draco is offline
Old 05-26-2003, 07:11 AM
96z
96z's Avatar
Looks like I may get the poly/poly ones. The twisties really aren't for me....
96z is offline
Old 05-26-2003, 09:02 AM
av8er's Avatar
Be prepared for more noise from the poly/poly. You will need to grease them frequently to keep that crushed Styrofoam sound from happening. I have the poly/poly and often think that the poly/rubber might have been a better choice.
JeffA
av8er is offline
Old 05-26-2003, 09:37 AM
ZDriver96's Avatar
i use tbryne poly/poly lcas... Keep em greases (twice a year) and they'll be fine. Mine make zero noise...
i've taken some corners pretty hard and everything feels fine. Perhaps under the most serious of conditions they'd bind but I have yet to feel that happen.
ZDriver96 is offline
96SilverRam
11-20-2016 11:19 AM
RUENUF
03-13-2016 03:37 PM
Henson071
09-18-2015 04:01 PM
Boss002
07-24-2015 10:47 AM
Quick Reply: Poly or Poly/rubber for LCA's
