Poly or Poly/rubber for LCA's
Im getting the BMR LCA's tues. Do you guys suggest the poly or poly/rubber combo.
What are the pro's and con's of both? |
Re: Poly or Poly/rubber for LCA's
Originally posted by 96z Im getting the BMR LCA's tues. Do you guys suggest the poly or poly/rubber combo. What are the pro's and con's of both? If you want to improve handling under hard cornering, go with poly/rubber, or better yet poly/spherical. If you want to go fast in a straight line, poly/poly will have an advantage controlling wheel hop (more traction). |
Looks like I may get the poly/poly ones. The twisties really aren't for me....:)
Be prepared for more noise from the poly/poly. You will need to grease them frequently to keep that crushed Styrofoam sound from happening. I have the poly/poly and often think that the poly/rubber might have been a better choice.
JeffA |
i use tbryne poly/poly lcas... Keep em greases (twice a year) and they'll be fine. Mine make zero noise...
i've taken some corners pretty hard and everything feels fine. Perhaps under the most serious of conditions they'd bind but I have yet to feel that happen. |
