Poly or Poly/rubber for LCA's
Old May 25, 2003 | 10:36 PM
96z's Avatar
96z
Im getting the BMR LCA's tues. Do you guys suggest the poly or poly/rubber combo.
What are the pro's and con's of both?
Old May 25, 2003 | 10:54 PM
Draco's Avatar
Re: Poly or Poly/rubber for LCA's
If you want to do any autoX or improve handling, stay away from Poly/Poly. You will experience bind as your cars body tries to roll on corners, and the poly bushings refuse to yield. If you get a poly/rubber setup, the rubber will compress as the LCA twists, and you will not have to worry about bind.
If you want to improve handling under hard cornering, go with poly/rubber, or better yet poly/spherical. If you want to go fast in a straight line, poly/poly will have an advantage controlling wheel hop (more traction).
Old May 26, 2003 | 07:11 AM
96z's Avatar
96z
Looks like I may get the poly/poly ones. The twisties really aren't for me....
Old May 26, 2003 | 09:02 AM
av8er's Avatar
Be prepared for more noise from the poly/poly. You will need to grease them frequently to keep that crushed Styrofoam sound from happening. I have the poly/poly and often think that the poly/rubber might have been a better choice.
JeffA
Old May 26, 2003 | 09:37 AM
ZDriver96's Avatar
i use tbryne poly/poly lcas... Keep em greases (twice a year) and they'll be fine. Mine make zero noise...
i've taken some corners pretty hard and everything feels fine. Perhaps under the most serious of conditions they'd bind but I have yet to feel that happen.
96SilverRam
Nov 20, 2016 11:19 AM
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
Boss002
Jul 24, 2015 10:47 AM
