It would just be common sense to replace all of the mounts right? Is polyurethane the way to go now aday?
This consists of 2 inserts for the engine and a torque arm bushing for the m6....is that it?
Thanks ---
Thanks ---
There are the 2 motor mounts, tranny mount, and TA mount that will all be apart anyway. I just got mine back together with all poly mounts, and its a little rougher than I wanted. If I cant get used to it I may put in a rubber tranny mount and see if that helps.
OOOOH thanks , I wasnt sure if there was a tranny mount. I cant seem to find a poly one for the m6 anywhere, can you link me !? ---
Re: Poly Motor AND m6 tranny mounts when rebuilding? ---
Quote:
It's the same as for the automatic.Originally Posted by alwayscode
Autozone should carry it.
Quote:
Several of the supporting vendors carry them.Originally Posted by alwayscode
I replace the motor mounts when I did the headers and I replaced the tranny mount when I did the clutch about a month ago.
Quote:
And the same for the entirety of the F-body lifespan beginning in 1967 says Prothane. Motor mounts and trans mount are a definite must IMO. Torque arm mount would be good to change too.Originally Posted by BradcTA
Great , thanks alot guys. I hear the poly mounts send a little more vibration...EXACTLY what I was looking for ( plus the LONG lifespan )
---Registered User
Quote:
You can tell the car vibrates if you focus on it...otherwise you cant really tell the difference besides the fact your motor isnt all over the engine bay and/or the tranny isnt about to fly up through the floor over big bumps.Originally Posted by alwayscode
go polly on everything! the performance gains far outway the vibration. With a big stroker I can barely feel the vibes. But, do the motor and tranny at the same time, or you may have problems! I have heard of people breakin crap cuz they only did one or the other. But, then you hear people like above who did it in stages. I guess it depends on how hard you drive your car. If you grandma it, then it wont matter. If you race everything that revs at you like me, go polly all the way!
