Poly Motor AND m6 tranny mounts when rebuilding? ---
It would just be common sense to replace all of the mounts right? Is polyurethane the way to go now aday?
This consists of 2 inserts for the engine and a torque arm bushing for the m6....is that it?
Thanks ---
Thanks ---
Re: Poly Motor AND m6 tranny mounts when rebuilding? ---
There are the 2 motor mounts, tranny mount, and TA mount that will all be apart anyway. I just got mine back together with all poly mounts, and its a little rougher than I wanted. If I cant get used to it I may put in a rubber tranny mount and see if that helps.
Originally Posted by alwayscode
OOOOH thanks , I wasnt sure if there was a tranny mount. I cant seem to find a poly one for the m6 anywhere, can you link me !? ---
Originally Posted by BradcTA
It's the same as for the automatic.
Great , thanks alot guys. I hear the poly mounts send a little more vibration...EXACTLY what I was looking for ( plus the LONG lifespan )
go polly on everything! the performance gains far outway the vibration. With a big stroker I can barely feel the vibes. But, do the motor and tranny at the same time, or you may have problems! I have heard of people breakin crap cuz they only did one or the other. But, then you hear people like above who did it in stages. I guess it depends on how hard you drive your car. If you grandma it, then it wont matter. If you race everything that revs at you like me, go polly all the way!
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
rpm4lalo
Aug 3, 2002 02:35 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
