plz help ??
fuel pump is an delphi hi pressure/ i have not tested the fuel pressure yet i will though/ starter and alternator are working fine about 1 or 2 old. is the stock fuel pressure reglator adjustable??
The stock fuel pressure regulator is not adjustable, and it doesn't need to be.
You should prime the pump, without starting the engine. Should be over 40psi. Then watch how fast the fuel pressure drops. If it drops quickly, its going to take longer for the engine to start.
ok i will do that ill let u know the results, so is that normal for a new fuel pump?
so lets say i tested the fuel pressure and drops quickly their for my engine will start slow,what would u recommend drop the tank again and this time use a dealer part?. the delphi i bought is an oem upgrade hi pressure fuel pump
There are other things that can cause a rapid pressure loss, including leaking fuel injectors and a faulty fuel pressure regulator. I wouldn't consider going into the tank until I had ruled out those two possibilities. Its pointless to spectulate until you check the fuel pressure.
ChoderBoy84CamaroZ28
3rd Gen / L98 Engine Tech
13
Mar 24, 2003 06:56 PM
