plz help ??
Old May 25, 2009 | 06:40 PM
OneFreakZ's Avatar
Question plz help ??
on my 94 z28 cranks afew times than fires up?? only happends on cold start ups, this just started to happend after i replaced my fuel pump and fuel pump relay.thanks
Old May 25, 2009 | 06:54 PM
JooneJune's Avatar
Whats your Fuel pressure at KOEO?
How old is your starter?
How old is your alternator and have you had a local shop (advanced auto, Autozone) hook it up and make sure its charging the system?
Old May 25, 2009 | 07:05 PM
n2ceptor's Avatar
What brand pump??? Delphi, Bosch, etc??? I have seen new pumps that do not produce the correct pressure...
Hows the fuel filter??
Old May 25, 2009 | 07:10 PM
Hal Fisher's Avatar
1freak, plz state what you problem is in the topic line
Hal
Old May 25, 2009 | 07:59 PM
OneFreakZ's Avatar
fuel pump is an delphi hi pressure/ i have not tested the fuel pressure yet i will though/ starter and alternator are working fine about 1 or 2 old. is the stock fuel pressure reglator adjustable??
Old May 25, 2009 | 10:45 PM
The stock fuel pressure regulator is not adjustable, and it doesn't need to be.
You should prime the pump, without starting the engine. Should be over 40psi. Then watch how fast the fuel pressure drops. If it drops quickly, its going to take longer for the engine to start.
Old May 25, 2009 | 11:44 PM
OneFreakZ's Avatar
ok i will do that ill let u know the results, so is that normal for a new fuel pump?
Old May 26, 2009 | 12:12 AM
Any fuel pump, new or old, has to hold the pressure in order for the engine to start quickly.
Old May 26, 2009 | 12:35 AM
OneFreakZ's Avatar
so lets say i tested the fuel pressure and drops quickly their for my engine will start slow,what would u recommend drop the tank again and this time use a dealer part?. the delphi i bought is an oem upgrade hi pressure fuel pump
Old May 26, 2009 | 05:00 AM
There are other things that can cause a rapid pressure loss, including leaking fuel injectors and a faulty fuel pressure regulator. I wouldn't consider going into the tank until I had ruled out those two possibilities. Its pointless to spectulate until you check the fuel pressure.
colts0455
Sep 11, 2015 06:16 PM
Jmj93z28
Jul 8, 2015 10:01 PM
BigTed187
Oct 7, 2003 03:34 PM
drewstealth
Jun 18, 2003 04:31 PM
ChoderBoy84CamaroZ28
3rd Gen / L98 Engine Tech
13
Mar 24, 2003 06:56 PM
