Plugs and Wires
Old Jan 9, 2004 | 11:51 AM
hozb817's Avatar
Plugs and Wires
I wanted to know what the best combo would be, I wanted to go with Taylor Thunder volt 10.4mm wires and NGK plugs. Any suggestions or would this be a good combo? Thanx for the imput!!!
Old Jan 9, 2004 | 11:56 AM
Mike383LT1's Avatar
wires & plugs
msd 8.5's and ngk tr6
Old Jan 9, 2004 | 12:02 PM
SlickBlack Z's Avatar
I second that.
Old Jan 9, 2004 | 12:04 PM
Loadre's Avatar
Accel Extreme 9000 wires and autolite 104s (for spray, your plugs would be different)
Worked perfectly.
Old Jan 9, 2004 | 12:07 PM
hozb817's Avatar
Loadre, I noticed a Mallory decal under your hood, do you have a Mallory ignition? If you do how is it working for you? Would you recommend it?? Thanx !!
Old Jan 9, 2004 | 12:17 PM
96YenkoClone's Avatar
i like the taylor spiro pro and they are not that expensive either
Old Jan 9, 2004 | 01:03 PM
Loadre's Avatar
I have the Mallory Hyfire VI CD (part #685) ignition box. Got it for the nitrous since it has a built in rev-limiter, window switch, and timing retard. It was confusing to wire up at first but all you have to do is buy a $30 connector and it plugs right in. You should see a pic or two of it if you scroll down on my cardomain site. It runs right about $220 and has worked flawlessly. I would recommend to anyone, ESPECIALLY if you plan to upgrade to nitrous.
Old Jan 9, 2004 | 02:20 PM
ABA383's Avatar
I have used the Accel 9000s and the stock type ACs in my stroker for 8 years with no issues...I do change plugs/wires every 2 years as scheduled maintenance...You may want to check out Thunderracing for their Taylor/Made-for-you over the valve covers wire & loom combo...$99.00 with a crimper...seems like a great idea. You know how muck of a pain it is to route the wires from underneath...I'm gonna check it out myself...I've seen other threads where people love the kit...
Old Jan 9, 2004 | 02:29 PM
gamecockfan04's Avatar
10.4mm ! Dont go above 8.5mm. 10.4mm is entirely too big.
Old Jan 9, 2004 | 06:37 PM
hozb817's Avatar
The bigger the better!!!!
Old Jan 9, 2004 | 06:43 PM
AsianSensation's Avatar
Earlier last year-MSDs and NGK TR55s.
Late last year-Taylors and AC Delcos.
Both are excellent setups.
Old Jan 9, 2004 | 11:04 PM
luis nunez's Avatar
41-906 ac delco
stock ac delco wires.
I had many problems with NGK, accel wires, borg warner wires
bosch +4
maybe is just my car
Old Jan 9, 2004 | 11:12 PM
FacelessZ's Avatar
Re: wires & plugs
NGK tr6's if you're running N2O...tr55's if not...
As far as wires go, stock replacement is fine...
Old Jan 10, 2004 | 01:32 AM
CamaroBoy96Z28's Avatar
Taylor 8mm Spiros and NGK TR55s here. Great so far.
Old Jan 10, 2004 | 04:08 AM
MentalCaseOne's Avatar
I second that.
Also routing your wires from underneath is time consuming. when you think you are done you find one or two wires are not where they are supposed to be (passenger side). I've a 95 twin cat and had to remove the Y pipe. Pain in the rear fer sure.
Marvin
PCLZ28
Dec 24, 2015 05:19 PM
charchri4
Apr 14, 2015 06:40 PM
eanhl2004
Apr 4, 2015 12:01 PM
IRABuss
Sep 7, 2011 09:08 PM
gh0st
Sep 1, 2002 10:24 AM
