Plug Wires Popping Off
Old Jul 13, 2009 | 09:15 PM
SmokeyBlaZe's Avatar
Ive had this happen two or three times, It will be misfiring and ticking, Ill push on the end of the plug wires and they will "pop" on to the plug. What can I do to stop it? I'm guessing that vibration is causing them to come off the plugs
Old Jul 13, 2009 | 09:42 PM
93FIRETURD's Avatar
Check for black exhaust looking deposits around the ceramic, some plugs can leak compression around those points this would easily cause you wires to pop off.
Old Jul 13, 2009 | 11:10 PM
So what is the solution ,What can I do about it? Crimp them?
Old Jul 14, 2009 | 12:54 AM
93FIRETURD's Avatar
well if you do have blowby a new set of or if you need to go cheap a new spark plug will do the trick
Old Jul 14, 2009 | 01:09 AM
I just put the new plugs in
Old Jul 14, 2009 | 05:12 AM
How old are the wires?
Old Jul 14, 2009 | 05:26 PM
no telling but they look good, I already have new wires I guess I should go ahead and change them out.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
