Plug Wire Opinions
Old Jun 3, 2003 | 11:54 AM
snorkelface's Avatar
Plug Wire Opinions
What are the some of the best plug wires out there for LT1s? I'm going to be installing headers soon, so I definitely be doing plug wires and spark plugs at the same time. It seems a lot of people like the stock spark plugs, any suggestions on those too? I want good performance, but also they need to have low noise.
TIA!
Hmm, maybe I should have posted this in the audio section...
Old Jun 3, 2003 | 01:21 PM
CeeBee94Z's Avatar
I just ordered the NGK-TR55 Iridiums and a set of OTVC Taylor wires from Thunder Racing...so I will be installing those soon....I suggest checking them out....it also depends if you want the plugs a degree colder than stock or not....the NGK's I got are the same heat range as the stock ones....
Old Jun 3, 2003 | 01:43 PM
joeSS97's Avatar
when i installed headers I also used Taylor OTVC wires.That was 25K+ miles ago and not a single miss.Some people dont like them.I think it is because you have to crimp them yourself.Which can lead to mistakes.My $.02
n2ceptor's Avatar
You might try conducting a search..these topics on plugs and wires have been going on for ever...
Old Jun 3, 2003 | 01:47 PM
I did a search in both the Lounge and LT1 Tech, and nothing came up that was useful. Sorry.
Old Jun 3, 2003 | 04:17 PM
jgonzales's Avatar
I did a search a few months ago, taylor wires seemed to be the most popular. I replaced some Accel's with Moroso wires and noticed a pretty big difference. About two weeks later I burned one of the Moroso's in half, so I replaced those with Taylor's and once again noticed a difference. No problems with the Taylor wires since then. I'd say go with Taylor wires. They were also some of the cheapest I found!
Old Jun 3, 2003 | 04:21 PM
I was looking on Thunder Racing's website, and liked the side-mount wire looms that come with the Taylor kit also. Does anyone have any experience with these and SLP dual cat headers?
Old Jun 3, 2003 | 04:28 PM
CeeBee94Z's Avatar
I like the side mount ones too, but I decided on the OTVC ones to keep them as far away from my edelbrocks as possible...just my 2 cents
Old Jun 3, 2003 | 04:29 PM
rocmemphis's Avatar
Never had a problem with my Taylor wires.
Old Jun 3, 2003 | 04:35 PM
So I take it you have SLP dual cat headers? Which wire loom are you using (over the valve cover, or side mount)?
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
