Please help very frustrated!!!
Old Mar 29, 2019 | 04:10 AM
Landon Moyers's Avatar
Ok done a motor swap from 1997 Camaro z28 to 1997 firebird formula I used the original pcm from camaro I also put a new Opti on it,put new plugs and wires on it, I gutted the cats put o2 simulators on it. It cranks but is throwing p0036 code and is backfiring when u let off the throttle and also on passenger side the manifold glows orange when it heats up but I figure that is from the excess fuel being dumped to compisate for the misfire? Could it be the Opti or injectors
Old Mar 29, 2019 | 10:19 AM
Re: Please help very frustrated!!!
Check the code.... there is no P0036 in OBD-2. There is DTC 36 in OBD-1, but you indicate you used a 97 PCM.
http://shbox.com/1/Dtcs.htm
Sounds like the timing may be off. Typically caused by not indexing the cam dowel pin correctly to the Opti drive. And, no, it doesn't only go together one way. Indexing the Opti incorrectly can cause P0336, crankshaft position sensor performance/out of range, to set. Is that the code you actually got?
http://shbox.com/1/opti_back.jpg
Or, maybe the rotor screw(s) fell out. Did you loc-tite them? Or, you bought a cheap Chinese rip-off Opti, and it's bad right out of the box.
Or, you have the plug wires routed incorrectly.
Old Mar 29, 2019 | 10:33 AM
Thank you so much for replying yes that was the code sorry. I have went by shbox wiring for the spark plugs and wires. Yes it was a cheap eBay distributor. I will go buy a new one from autozone with a lifetime warranty. Will that work?
Old Mar 29, 2019 | 10:37 AM
That was the code sorry and I did buy a distributor off ebay.i used his spark plugs and wiring diagram to put those on. I will go buy a good distributor from autozone with a lifetime warranty today will that work
Old Mar 29, 2019 | 12:06 PM
Before buying a new distributor, check to see if the dowel pin was located in the correct hole. Even with a new, high quality Opti (and Auto Zone is not necessarily “high quality”), it isn’t going to run right if you don’t get the dowel pin indexed correctly.
Did the Opti seat correctly on the timing cover BEFORE you tightened the bolts? Or did you possibly use tightening the bolts to pull the Opti down against the timing cover? Common mistake. Did you check the length of the dowel pin to be sure it would fully engage the correct hole? A too short pin can slip and end up in the cloverleaf section of the Opti, and will cause P0336 to set, because the cam position signal from the Opti is out of phase with the crank position signal from the CKP sensor.
Old Mar 29, 2019 | 12:22 PM
It took a few times but it did set flush without the bolts tightening it up,so as far as I know it was. I went and bought a brand new one and the mechanic is going to line it up correctly according to shbox.
Old Mar 29, 2019 | 01:21 PM
Info on correct dowel pin length - read first paragraph.
4th Gen LT1 F-body Cam Install
Old Mar 29, 2019 | 08:32 PM
Ok change Opti now KSP sensor code went away now it's throwing a p1373 any ideas
Old Mar 29, 2019 | 10:50 PM
P1373 is not a valid code for 97 LT1 f-body. Must have been something else.
Old Mar 29, 2019 | 11:24 PM
I'll take a guess.... P1371 - loss of low resolution pulse from the Opti optical cam position sensor. Could be another cheap Opti, or there could be a problem with the Opti harness connector, if that's the code.
So....is it starting, is it running better, same as before?
Rob- I gave him the link to your LT1 code list, but he must not have looked at it.
Chevy053
Apr 23, 2008 12:15 PM
Roscoe267
Sep 15, 2005 12:48 PM
Hawk
Feb 22, 2005 07:32 PM
Valkyn71
Jul 27, 2004 10:52 AM
95z28 -quicksilver
Apr 9, 2004 04:17 PM
