How bad could this be hurting my performance? (pic)
Old Jul 26, 2004 | 10:19 AM
Valkyn71's Avatar
After going to the track and running mid 15s at 94mph, with my full bolton and cam car i started looking for what could be wrong
I was getting an opti code, specifically the wiring harness going into the opti, so i pulled the plug out and Here is what i found.
So can anyone tell me how much this could really be hurting my performance? I have a new opti and plugs/wires.
Old Jul 26, 2004 | 10:27 AM
Hyperspeed97z28's Avatar
Re: How bad could this be hurting my performance? (pic)
By the way that plug is looking.. I'd have to say that very well could be killing some performance....
Old Jul 26, 2004 | 10:51 AM
Loadre's Avatar
Well I'd say if you're getting an opti code and the thing looks like that then it's definetely part of your problem.
Old Jul 26, 2004 | 08:09 PM
Valkyn71's Avatar
I dont see how it could be hurting me 2 seconds worth tho. As long as all the cylinders are getting spark it couldnt affect much else could it?
Old Jul 26, 2004 | 08:23 PM
Loadre's Avatar
It's hurting you bad enough to throw a code.
No I'd say that is not your whole problem, though.
Old Jul 27, 2004 | 10:25 AM
HBHRacing's Avatar
what code is it? a high res code? you better belive thats hurting you. if your lacking the high res signal then your ign timing is based on the low res signal which means bad performance, gas milage... can;t say that it's hurting you 2 seconds worth but it is hurting
Old Jul 27, 2004 | 10:52 AM
madwolf's Avatar
A bad opti could cost as much as 100 RWHP or more on a cam/heads car. I've seen live proof of that on a dyno just a couple of days ago. (AFR was right at 13)
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
