please help,a/f ratio gauge wire
Old Nov 25, 2003 | 11:47 AM
YOSHI`S Z28's Avatar
hey,
having a lil problem, i have one wire to hook up on my a/f gauge.
it needs to go to the o2 signal wire that goes to the pcm. i lost my wiring diagram so does anyone know what color i need to hook it up to..
thanks
josh
Old Nov 25, 2003 | 12:43 PM
1msfyter's Avatar
Purple wire. Look under hood and find the wiring harness that goes to the O2 sensor(easiest is on pasenger side) Its purple. Follow it back to the midway point . I tapped into it . Very easy.
Driver side is purple and white .
Old Nov 25, 2003 | 01:24 PM
Both O2 sensor signal wires go to Connector "C" (grey) on the PCM. Drivers side is purple/white wire to pin C20. Passenger side is purple wire to pin C8. Splice into both of them, run them to a single-pole/double-throw switch, and you will be able to select either sensor for the meter.
97ss1826
Mar 13, 2003 11:58 AM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
